LTspice folder organization that works for you?
Murrayatuptown
Post by Murrayatuptown »
I can create a simple schematic and run a simulation in LTspice.
When someone gives me a hand up and shares, or I download a posted .asc file, I struggle to place various added items that are included via .INC statements etc.
Obviously, I either need those components, and/or need to put them in a folder LTspice expects them to be.
For some people this is simple and trouble-free.
I suppose it might be possible to paste the contents of the .lib, etc. files into a .asc file to make it self-standing. (Making the files more complicated & ripe for additional syntax errors).
Or it should be easier to learn a simple set of rules for folder organization that work for other people.
Windows pretty readily adapts to any sloppy download location of borrowed .asc files by file-association...but following the rules for LTspice .INC and other ways of calling libraries, models, sub-circuits, etc seems like a smarter thing to learn.
What do you folks suggest, based on what works for you?
Murray
Murrayatuptown
Re: LTspice folder organization that works for you?
I got it figured out. Doesn't sound like much, but it works again!
Murray
tmknight
Post by tmknight »
Though, you said you figured it out, seems you may not understand why?
To be sure, you "can" place all of your .lib/.inc files anywhere you want...as long as that path is referenced in LTS library search path in the control panel. The default path (on Windows) is $env:userprofile\Documents\LTspiceXVII\lib.
You will also need to reference those .lib/.inc file names in your schematic. You can place multiple references in a single directive. As long as the .lib/.inc is in a known library path, LTS will find it.
