New Amp - The Lancaster
Littlewyan
Post by Littlewyan »
After building multiple amps all with the purpose of creating overdrive I thought it was about time I built myself a clean amp. And here it is! The Lancaster. Named after the bomber plane, simply because I named the last amp The Vulcan. 15W 6V6 two channel amp. One channel is based off of the Songwriter 30 preamp and the other is Fender based with some extra features and small tweaks.
I went over on the transformers, the Edcor OT is a 25W unit, the choke is for an AC30 and the PT handles the power so easily that the HT only sags by 7V flat out.
Tonally it sounds incredible, dead pleased with it. As you can imagine with those transformers the bottom end is huge. For once I feel no need to tweak anything, just need to enjoy playing it :D
joeboo88
Re: New Amp - The Lancaster
Post by joeboo88 »
What a great build. a lot of thought went into your layout... Great name as well.
guitarmike2107
Post by guitarmike2107 »
Very nice work. Well done!
gktamps
Post by gktamps »
Very nice indeed! Very clean build.
I just went the same route - so many of my builds have great distortion, so I just reverted my 18 Watt reverb rocket to stock, clean configuration.
Break out the pedals!
Just had to deepen the jealousy with the no tweeks statement. :roll:
It looks great!
Littlewyan
Thanks all. I just need to fit it into the combo cab. I’ve got a Creamback M65 in there at the moment and want to swap it for an actual Greenback G12M. Never could get on with the Creamback speakers.
Colossal
Post by Colossal »
What a great build! Very nice!
