This is the amp schematic, page 21:
http://www.acofs.org.au/part_5_files/Be ... 614EVM.pdf
The fuses blow instantly when the amp is powered on. I am using the correct 8/10 125A fuses for the amp.
https://robrobinette.com/Tube_Guitar_Am ... lows_Fuses
Following the above guide on tracing blown fuses, I did the following with my light bulb limiter with a 75 watt bulb:
Amp with no tubes installed - light bulb limiter is DIM.
Amp with both rectifier tubes installed (there are two 6x4), DIM.
Amp with both rectifiers in, and first preamp tube, DIM.
Amp with both rectifiers in, pull first preamp, and second preamp tube in, DIM.
Amp with both rectifiers in, preamps out, first power tube (6aq5), BRIGHT. Tried 5 different 6aq5 tubes to deduce if bad tube, still BRIGHT.
As I then understand it, there is a short in the output tube related section. I have traced every wire, inspected the turret board, inspected the tube sockets, everything that I can think of, and can't figure out where the problem would be. Following advice on another forum I am part of, I replaced components in the power tube circuit (which I was going to mod with slightly better guitar related values anyway), as well as changed both power tube sockets. Problem persists. Possible PT issue? I do have an extra vintage PT from the same type of amp that I could swap in if needed.
I've been on The Amp Garage for many years, but only recently started working on tube amps myself. I've modded maybe 10 vintage tube amps so far all with great results. Fun, but this one has been a challenge given my inexperience.
Any ideas on what to do next?
This morning I did come across these two things from here on The Amp Garage, wondering if there is a good next step outlined in either for me to try?
https://ampgarage.com/forum/viewtopic.php?f=6&t=32210
http://www.geofex.com/ampdbug/fuseblow.htm
I appreciate any advice (or help in Seattle) from anyone who can chime in!
Here is a shot of the full amp circuit:
Here is the PT:
Power section components, some replaced (problem identical before and after replacement):
Power tube sockets (before replacement, problem identical before and after replacement):
This is how filter caps go in, they plug in like tubes into sockets. The missing (film related) components were clipped off and weren't connected to the caps. Those pins aren't used:
