"It helps if you think of the equation for power: P = V^2/R. If you have 100W into 16 ohms, the voltage is V = sqrt(100*16) = 40V RMS. If you have 100W into 8 ohms, the voltage is V = sqrt(100*8) = 28.28V RMS. If you have 100W into 4 ohms, the voltage is V = sqrt(100*4) = 20V RMS."
Just looking at this ratio, is it accurate to say that, for a switch from 4 ohm to 8 ohm output impedance, if the stock resistor off the 4-ohm tap is 56K, I can calculate the appropriate 8-ohm tap NFB resistor value to allow for the same NFB voltage would be 56K * (28.28/20) = 56K * (1.414) = 79K?
