with no guitar plug in, 100hz (tested with tuner)buzz/hum is very loud with volume up from 1 along with loud hiss,with volume to zero there is no hiss or buzz/hum,if i connect only first stage direct to tone stack buzz and hiss is low on max volume.
I changed all filter and signal caps
DC or AC heaters =no change in buzz/hum
i have artificial 100 Ohm center tap on heaters from el34 pin 2-7 to pin 1-8 ground
all resistors are metal film,
voltages on all tubes are normal,
grounding form rectifier to first filter cap,
all power amp grounds to one point near PT
all preamp grounds to input
changed all tubes, tube sockets and diodes,
re-soldered many times all connections to ground
temporary lifted chassis ground
connecting direct ground from other wall socked to chassis with no difference
to me sounds like ground loop somewhere but i have no idea what next to try
on the photo fourth stage and fx loop is disconnected,ignore that
