Hi all, I'll soon be taking possession of a dual EL84, 6CA4 recto & a single 6EU7 preamp tube. The only experience I've had w/the 6EU7 is with some older Gibsons. It's a broad question, w/many variables, but- what tube might offer the best overdrive, if the 6EU7 falls, 1short; a 12AX7, or perhaps a EF86/6267 tube for some early Vox-like breakup? I really NY tech would need to pull off some rewiring of the front end, but hopefully with good OD results, & a worthwhile venture?
Thnx in advance for any suggestions~
Reworking The Preamp Section
Re:Reworking The Preamp Section
6EU7 is essentially a 12AX7 with 6V-only heater and different pinout.
