RN65s
- dorrisant
RN65s
Where are these sourced from? Seems I got a bunch a while back, Now nobody seems to carry very many. Can't find a vendor that actually has 100k, 120k, 150k and 220k in stock.
Re: RN65s
Did you try Mouser electronics?
Re: RN65s
google dale rn65
- dorrisant
Re: RN65s
Mouser is out of stock on most values. That was where I got them before.
Googling takes you to Mouser and Digikey... both tend to cloud the results with false hopes... out of stock. Others in the list are not even close to the correct part number.
Lots of possibilities end up being out of stock, especially the Digikey listings. Kinda shitty to spend that much time clicking on out of stock links. F-U Digikey or Google!! Also, it doesn't matter if you put the value in the search, quotation marks or not. It is gonna show me random values (usually a sign of no availability). I wish this was better regulated.
This is why I posted.
Re: RN65s
On Mouser, type rn65d in the part number field and hit return.
- dorrisant
Re: RN65s
Ok... but only 100k and 220k available in 1/2 watt.martin manning wrote: ↑Mon Sep 06, 2021 8:07 pm On Mouser, type rn65d in the part number field and hit return.
Thanks Dave, I may hit you up for a few...
Why would I have ever thought anything about sourcing D parts would be easy anyway?
- FUCHSAUDIO
- dorrisant
Re: RN65s
Yes, thank you Andy, for pointing that out. But it is all a part of understanding... get 'em while you can.
And thank you Dave. I got those resistors. Serious coupons on your next board set!
