JMI AC30/6 NO SOUND
JMI AC30/6 NO SOUND
Hi, my JMI AC30/6 turn on, everythin is working but it doesn´t make any sound, no hum no hiss (Nothing!)
Some recommendation about how to check where is the problem??
Thanks.
Thanks.
Re: JMI AC30/6 NO SOUND
If it was working the last time you played it and turned it off then the chances are really good that a output tube blew on you when you fired it back up, and that took out the amps internal DC power supply fuse.
Thanks, How can I check if tubes are un good conditions?
I build and repair some amps but I'm still learning
If you have another amp there look into the output tubes when you take it off standby and into play mode, you will see a blueish white flash as the tubes get there needed DC power.
If this does not happen to any of the 4 output tubes in the Vox then DC supply is open .
You can further check with a voltmeter by hooking it up to pin 1 or 6 of any of the preamp tubes.
With that check you should read at least 90 volts DC on any of those pins.
Can you post up a schematic of this model Vox for us?
It´s like this one http://www.pisotones.com/Alfonso/JMI/JMI_30-6.htm
So I must read pin 1 or 6 of preamp tubes?
Thank you guy
Thank you guy
Vintage Vox don’t got no stinking standby
If there’s no hiss / hum, it’s probably most expedient to check pins 1&6 of the LTP phase splitter V2, at ghe far end, below the tone control.
Are you sure that the speakers are connected?
Yes, speakers are connected. I will check pins 1 and 6 of V2 today!
Thanks again
Thanks again
Are you sure they’re good?
It would be regrettable to wreck an OT due to a failed speaker being assumed to be ok.
No, that’s the top boost valve / circuit.
AC30/6 schematic https://el34world.com/charts/Schematics ... 301960.pdf
0.685 on pin 1
0.740 on pin 6
0.740 on pin 6
All 12AX7 same values around 0.7
So have you got any decent HT voltage anywhere in the preamp chassis? eg on the big filter caps.
