What I'm picturing is:
Standard V1a input stage with 1k5/25uF and 2k7/.68uF cathode on a switch.
Two coupling caps, one into a fender preamp and the other into a marshall preamp.
Fender preamp: tonestack -> volume control -> V1b gain stage -> coupling cap -> 220k mixer resistor
Marshall preamp: volume control -> 470k/470p -> V2 DC CF -> tonestack -> 220k mixer resistor
As far as I can see this should be a pretty simple and straight forward build.
Will there be any problems having two coupling caps off of the same plate, aside from the extra AC load due to the Fender tonestack and volume control being in parallel with the Marshall volume control?
It's clearly not gonna be exact replicas of the Fender/Marshall preamps, so some tweaking and compensating here and there is totally fine. I really like having two different voiced channels in the same amp, and even more having the possibility to blend them, which to me is the holy grail of adjustability
I've read a lot through the forums about parallel preamp channels, blending, in and out of phase and what not, but never seen anyone hook two coupling caps to a single triode, which except from an extensive switching setup may be the most effective way to make the most out of a single triode. Anyway, it got me thinking there has to be a reason I've never seen this before
All ideas and thoughts are welcome.
