Schematic Software
bryankloos
Schematic Software
Post by bryankloos »
Hey All,
I want to start drafting some schematics for design/R&D and for submission here for critique.
In order to save everyone time and hassle, I'd like to draft something clean, neat and professional.
What software are you all using to draft/edit schematics?
All help is appreciated.
Thanks!
Bryan
pompeiisneaks
Site Admin
Re: Schematic Software
Post by pompeiisneaks »
tUber Nerd!
thetragichero
Post by thetragichero »
diy layout creator is an option. i haven't produced any complete schematics with it (I'm a pen and paper guy) but messed around without actually reading instructions and it's fairly intuitive, drag-and-drop
pompeiisneaks
Site Admin
thetragichero wrote: Wed Feb 24, 2021 6:50 pm diy layout creator is an option. i haven't produced any complete schematics with it (I'm a pen and paper guy) but messed around without actually reading instructions and it's fairly intuitive, drag-and-drop
I didn't know it had any schematic features? I thought it was only layout. Interesting.
~Phil
tUber Nerd!
ViperDoc
Post by ViperDoc »
KiCAD is quite powerful and easy to use once you get the hang of it.
Just plug it in, man.
thetragichero
i haven't used it to make layouts either.... have an ancient windows xp laptop i threw memory and an ssd in and installed ubuntu (to be my reference material when working on bulbs instead of my little phone screen) so really i was just testing that it would run on the without issue, but i dragged the triode symbol to the workspace along with the usual cap/resistors on an amp input stage. what can they be exported as? no clue, at the very least a screenshot could be taken
T Wilcox
Post by T Wilcox »
+1 on Kicad
Also has the benefit that you can design a PCB off your design as well. If you are not a fan of PCB you can also create eyelet boards as well and stake your own eyelets. I've also used it to make a drill template for an eyelet board with great success.
If only for drafting the schem there may be other programs that look fancier
Microcap is another option although I havent spent much time with it yet
mhuss
Post by mhuss »
I use KiCAD when I need to make a PCB, but the schematics are rather 'dry' (simple example attached).
Another free option is ExpressSCH, which is a little easier to learn, and does a decent job of making readable schematics. Example output here: https://mhuss.com/amps/Express/Express.pdf
Aurora
Post by Aurora »
There's Eagle, KiCad and several minor ones..... commercial versions are from expensive, to very expensive....
Eagle has a fre version and an upgrade paid version.... KiCAd seems very good ( have just started), but has it's kinks, but frankly, they all do.. Most of these programs have rather steep learning curve..... KiCad is community software, - sort of shareware, with what seems like good tutorials and forum....
There's also some pcb only prog's, but the basis og a good layout is the schematic with it's netlist and footprint definitions...
I've been using OrCAD / Cadence for years, but that's another ballgame....
Aurora
Post by Aurora »
Eagle has a fre version and an upgrade paid version....There's also some pcb only prog's, but the basis of a good layout is the schematic with it's netlist and footprint definitions...
Most of these programs have rather steep learning curves..... KiCad is community software, - sort of shareware, with what seems like good tutorials and forum.... and there's a tube library.......I've been using OrCAD / Cadence for years, but that's another ballgame....
imjonwain
Post by imjonwain »
If you have the interest in learning it KiCad is a great option. It's free and under active development. I've recently switched most of my projects over to it from an old Eagle license. Only thing worth noting is KiCad 6.0 will be out in a few months and is quite a major overall from 5.9.1 so you'll be relearning again.
https://tfrelectronics.com/
https://oshpark.com/profiles/TFRelectronics
sluckey
Post by sluckey »
I use Visio for all my electrical drawings. Not cheap and there is a learning curve. Visio also does a zillion other drawings and contains plenty of stencils to occupy your mind 24/7, if so desired. Heck I even mapped out sprinkler systems, landscapes, etc. Here's an example of my final amp project...
http://sluckeyamps.com/phoenix/phoenix.pdf
bryankloos
Skluckey,
Clearly you like visio, and your diagrams and schems look really nice.
Did you have to import/build many of the items for both layout, rendering and schem or were they contained on the software?
How was the learning curve?
I like the idea to have schematic, layout, and rendering all on one package.
I'm going to play with expresssch today and see how I get along, but open to alternatives that may also be useful outside of amps...
All input is appreciated.
Thanks,
Bryan
sluckey
Post by sluckey »
I started using Visio in the early '90s when Version 1.0 was released by Shapeware. All it could do back then was flow charts and organization charts. Easy stuff. I've owned every version up to Visio 2010, so I grew up with Visio, and my skills grew as Visio became more sophisticated. It would likely be a bit intimidating/challenging to anyone that started cold with the latest version. The engineering templates such as the electrical stencils were only available in the professional version of Visio back in 2010. Probably the same today. All my schematics are drawn using the templates and stencils included with Visio Pro. All the symbols you see in my layout drawings were custom made by me and are freely available on my website. The sizes are correctly scaled so that what you draw closely represents what you would actually build. This allows you to see what the real layout will look like. You can even use my drill guides to create a full size board. (See attachment).
mhuss
Post by mhuss »
I find the software best for drawing schematics is not the software best for creating layouts. (The original question was about schematics.)
Visio, while costing a few bucks, can clearly make very nice layouts with enough work and experience!
This is straying into the area of stereotypes :), but it seems designers/engineering types prefer to look at schematics, but builders refer layouts. I am more in the former camp, and certainly have a harder time figuring out (as opposed to building) layouts.
In other words, if I'm figuring out how a circuit works, or answering a design question, I'd much rather have a schematic.
If I'm building a known design, I'd rather have a layout.
Neither is intrinsically better, but each has uses and strengths.
