Possible Master or Gain Increase Mod?
zozoe
Post by zozoe »
Hi all~ I'm not sure if that more detailed one is for my amp, but that preamp tube setup is... Are there any feasible thoughts on a functional, NON tone sucking master for it? OR, a component's or 2 or 3 values to change to it give much more gain at a lower level?
Amp has 2xEL74, 2xAX7's, & 5U4,,,,
Thnx in advance
pompeiisneaks
Site Admin
Re: Possible Master or Gain Increase Mod?
Post by pompeiisneaks »
Please do not create duplicate threads. I'm deleting the other. I can see your images just fine.
I don't really understand what you're asking, so i didn't respond.
~Phil
tUber Nerd!
Post by Stevem »
On V1A why do you have a resistor to ground off of the cathode bypass cap?
Also you need to post up a bigger better picture of the schematic and you layout drawing please!
zozoe
Post by zozoe »
The dupe post was an error, Phil. Kindly forgive, but my question was if the only schemes available to me, tell you anything about the possibility of inserting a master, or some mod for earlier breakup (w/o using those tone-suck attenuators)?
Thnx again, & be well~
zozoe
Post by zozoe »
Stevem,, this is how the amp was built, with that V1A thing you mentioned,,, I do not have a clearer picture of the entire layout,,, I'm lucky to have this much info.
Thnx
roberto
Post by roberto »
So joining schematic and layout we can say that the amp is:
100k & 1k||(680n + 20k)
10n to 1Mlog vol
100k & 1k5||22u
Tone stack
Loop
Paraphase PI
Power tubes
thetragichero
Post by thetragichero »
can you upload the schematic you took a screenshot of instead of the screenshot? zooming in it looks like 💩 all pixelated
roberto
Post by roberto »
Convert the paraphase into a concertina and use the free triode, get rid of the loop and squeeze some more gain.
Post by Stevem »
Those mods will help gain wise, but the end result is the amp will still be nearly just as unusable loud for him!
He needs a master volume, or to power scale the amp which requires a master volume anyway!
The third thing would be to try a good sounding distortion stomp box in that non buffered effects loop, or just in front of the amp to begin with,
Get a 50w L-pad from Amazon and use as speaker attenuator.
