Is there high torque push pull pot?
psychepool
Post by psychepool »
I like to use high torque pot for tube amp build because it feels good when turn it.
Every time I make a new amp, I try to use the high torque pot as much as possible.
I'm trying to do some mods on the amp I'm making now, but I don't have a place to mount a switch on the panel, so I think I'll have to use the DPDT push-pull pot.
However, none of the push-pull pots I've ever used have high torque.
I searched and found that CTS had a DPDT pot with high torque. However, the product has a body diameter of 24mm, so I don't think there is a place to mount it on my amp panel.
Are there any 16mm DPDT push-pull pots with high torque? If you know any products, please recommend them to me.
