I'll put the TL;DR next with the meat of the matter and after that I'll add additional background.
I took a stock Fender Champion 600, gutted it down and reused only the wood cabinet, the power cord, and the metal chassis. I built the entire rest of the amp from ground up. I used the standard 5F1 schematic. All components are the value listed on the 5F1 schemo with power ratings equal to or above. The mods I added are Uncle Doug's variable negative feedback with a 5k resistor and ~48k pot replacing the 22k resistor. That appears to work as designed. I also did Rob Robinette's selectable solid state / tube rectification mod - this also appears to work as designed and has no effect on the problems I'm having.
2 problems I'm having:
1) Pilot light turns on for about 30 seconds then burns out. I tried searching the web for pilot light wiring info but it seems the pilot light is more of an afterthought in these regards. I attached a picture of exactly how I have it wired.
- does it matter that the pilot is last in the run? It's wired 1st in every schematic I've seen.
- does it matter that the schematic has the wire from 6V6 pin 7 to 12AX7 pin 9 but I have pin 7 to pin 4 & vice versa with the other 6.3 wire (see my picture)?
- the negative lug on my pilot light is bonded to the metal body of the pilot light housing which then becomes a chassis ground - is this right / normal?
I measure 6.5 volts A/C on the 2 green 6.3 volt wires. When I mount the pilot light holder to the chassis and measure the base (+) and the chassis body (which is bonded to ground because it's made of metal) I measure 3.0 volts A/C.
2) The amp sounds really good except when I turn the volume up, after almost exactly half way up it seems it breaches some threshold and the guitar signal immediately then gets very weak and the amp starts to distort really badly. It's not a nice gradual rise in good tube breakup as I turn the volume up - the sound is nice and clean until half way up and then higher than that certain threshold it's like a switch if flipped and it just sounds like crap above that.
Any suggestions on where to look for problems? I will gladly supply photos or multimeter readings.
--BACKGROUND--
This is my 1st amp build. I did do a few years of commercial / industrial electrical work in the past and I have also built about a dozen or so guitar effects pedals recently. I did take electronics in tech school but that was a million years ago. I have a fundamental understanding of electronics but I'm more of a tech / parts-changer as opposed to being an engineer.
When I first finished this build the pilot light hadn't been delivered yet so I wired all the tubes leaving a taped up pair of green wires for the pilot. Everything seemed to work perfectly. The bias was a little hot at 115% over the 12 watt max.
When I received the pilot light I installed that as well as changed the cathode bias resistor to bring the bias down to around 95% (on paper). After that it hasn't seemed to work right since. The pilot lights don't last more than 30 seconds and with the volume above half way I lose guitar signal and get awful distortion. Turning the volume knob up the amp sounds great until I get to one specific spot and it just farts out above that spot. I never had turned the volume about 7 or 8 even before I made the changes so I don't know if it always had this problem but that threshold was above 7/8 and I never reached it. I haven't measured the new bias and I haven't energized the circuit after blowing up the 2nd pilot light because I wanted to run this by the amp building community first to get your thoughts, opinions and advise.
Any help & guidance is greatly appreciated!!
