Digital Thermometer to monitor bias
I started taking my amps temperature. Its interesting to see what actual F temps are on the tubes. is there any protocol for using temperature readings to set bias? Sorry if this is a crazy question.
Re: Digital Thermometer to monitor bias
That's a crazy question so don't let your mind stay there for you long, but in the original tube data sheets there is a max temp number they give.
There's no protocol because the bulb temperature depends on:
- initial bias current and B+ voltage;
- loadline;
- signal applied;
- class of the amp;
- temperature of the surrounding air;
- speed of the surrounding air;
- temperature of the surrounding items;
- colour of the surrounding items.
But generally speaking most tubes suggest not to exceed 250 °C as bulb temperature.
- loadline;
- signal applied;
- class of the amp;
