professormudd wrote: ↑Thu Oct 22, 2020 7:52 pm
Greetings,
I have attempted to search, but finding answers through the massive amount of results shows that I do not know enough to even form the best search query. So, I apologize in advance if this is a redundant question.
Please refer to the layout.
I just completed the assembly of a Brown Note D-Lite Blue Monkey 44. I was preparing to start it up for the first time and I was ready to set the bias on the power tubes. Below are a list of my steps along with questions:
- I was to believe that this amplifier can handle 2 6L6 or 4 6V6 power tubes. I installed 2 apex-matched JJ 6L6GC power tubes. One in V6, the other in V7. Are these the correct tube sockets to install the tubes?
- I measured the voltage from pin 3 on each of the tubes. V6 was 505v, v7 was 507v. This seems high, but I do not know.
- I used the calculator from AmplifiedParts.com to get 100% bias point of 59.41mA for V6 and 59.17mA for V7.
- I inserted my multimeter probes into the bias tip jacks for each of the sockets. I set V7 using the first bias pot (B1). When I inserted the probe into the tip jack for V6, it was only reading between 10-17. This is the point I stopped because I am confused.
Would anyone be so kind as to walk me through adjusting bias on this particular amplifier?
Did the readings I take make any of you raise eyebrows?
1. if you are going to only install 2 of the 4 tubes, you just need to ensure one tube per half of the OT windings. I think, if you're saying that the tube count starts at the first preamp tube is V1 and there are 4 preamp tubes, V1,V2,V3,V4, then V5,V6,V7,V8 going in that line are the 4 power tubes.
you coudl either use V5,V7, or V6,V8, or V5/V8 Meaning the 'pairs' that must not be 'alone' are V5/V6 or V7/V8.... any other combination works...
2. If the amp isn't warm and isn't outputting any sound etc, or if it's on standby, it will be higher voltage until the tubes start conducting (also if you only have two power tubes and not all preamp tubes it may run higher as well, each tube adds an overall voltage drop to the B+ rail)
3. yes but I"m hoping you don't want to set it at 100% but instead are going to set it at about 70% dissipation which is the correct setting for grid biased tubes.
4. That reading makes no sense. If you're setting your multimeter to milliamps, then you're doing it incorrectly... you need to set it to read voltages. The 1R resistors then give you an ohms law value of mA directly from the mV reading:
V = I*R
V = I * 1. = V = I
so maybe you're on milliamps reading and just pulling a few milliamps from around the cathode 1R resistor and getting bad readings?
If you've set it to VDC and are getting 10-17mA then your'e biased very cold and would need to dial it up until you get ratings you'll expect/want.
BUT an amp is going to work optimally with the 4 power tubes that the OT was designed for, becuase the OT reflects the right impedance back from what was expected. On the other hand if you want to, you can adjust the speaker load accordingly. I can never remember if it's up or down, but basically if you're halving the impedance of the power tubes I think you need to inversly increase the speaker load to bring the impedance ratio back up...
Therefore, if you have the impedance of the speaker set to say 8 ohms, and you're only using 2 tubes you should likely use 16 ohm speakers on the 8 ohm setup (hopefully someone corrects me if I have that backwards)
~Phil
