Greetings,
I recently procured a partially completed Brown Note Blue Monkey 44 kit. On the section of the layout for the bias, It looks like the resistors are to be connected to the nut on the connectors.
How is this typically done? Should I stick some soldering lugs under those nuts?
Any assistance is appreciated.
I would appreciate some help interpreting soldering point on this layout
professormudd
-Matt
It may very well be that the sole purpose of your life is only to serve as a warning to others.
sluckey
Re: I would appreciate some help interpreting soldering point on this layout
All resistors are connected to the pins. Nothing is connected to the nuts.
professormudd
Thank you.
-Matt
