So now, I have a Schecter Hellwin on the bench... Oh Boy! I hate it. Anyway, it came to me not working fresh from an auction site. It had a 220v mains PT so that wasn't gonna work. Customer wants it bad so I send the good but 220v PT to Patrick @ MM. After a reasonable time, he sends a replacement wired for 120v. All good but the bias. This thing is running EL34s with 450v on the plates and average of 60mA for each power tube. It has a switch for EL34/6L6 operation. Change that to 6L6... now it idles at 55mA per tube. Still too high. Check the bias voltage... -32v. No dice! I'm starting to think the winding for the bias may be wound wrong at this point. Bias circuit seems like it has been run from a 13-0-13 tap... This, by way of deduction must be the relay supply as well. All of the relays are working so no need to worry... Checking the EL34/6L6 switch... it seems to be changing the voltage for the OT CT. It is not changing the bias voltage on pins 5. So, if I just get the bias a bit more negative then it should work for both EL34 and 6L6. Now I notice that the HT winding is connected to a full wave bridge rectifier. Not a problem, just like in the thread at the link above, right? Wrong! I used basically the same supply that I posted as a pdf on the 2nd page. (posted below too). I thought I was gonna breeze right through this... Ha ha!
What gives?
I tried everything I could think of so far. I even tried the normal way of tapping the HT... HT tap -> 220k -> diode -> etc.. Nothing as far as DC.
With the cap fed circuit, I measure 185vac and 223vdc where the cap is connected to the HT secondary winding. On the other end of the class xy cap (@ the reversed diode) I measure 87vac and 53vdc. After the reversed diode there is less than 1 vac and -7 vdc. I am at a loss and so is the customer.
And, there is NO SCHEMATIC TO BE FOUND, change my mind.
I should have never accepted this amp. No more cheap PCB amps!
