Moderators: pompeiisneaks , Colossal
ChopSauce
Posts: 1045 Joined: Wed Mar 15, 2017 12:08 pm
Post
by ChopSauce » Tue Jun 09, 2020 7:51 am
Essentially, I'd like to know where I could find pilot lights looking like that one
whatever the color - preferably in Europe -
I wouldn't mind any other suggestions, though...
thetragichero
Posts: 478 Joined: Tue Sep 10, 2019 7:46 pm
Post
by thetragichero » Wed Jun 10, 2020 2:48 am
I've switched to leds. 1n4001 or whatever attached in parallel (opposite polarity of the led) and ~10k current limiting diode (for those clear super bright leds it's still brighter'n'ell), attached to the heater string
then you can put it in anything you'd like
PRR wrote:
Plotting loadlines is only for the truly desperate, or terminally bored.
ChopSauce
Post
by ChopSauce » Thu Jun 11, 2020 7:38 am
Thanks for the link to xtian's. The above cab is from the Deluxe Speed Shop. I think it is poplar. See:
http://www.tweeddeluxe.com/cabinets_heads.cfm
NB I thought the main advantage of the LED was having it drain the HT rather than having it on the 6.3V...
EDIT: I thought I had posted this earlier...
I found a very close looking lens, to screw into a Fender style bulb support at Modulus amp.
