Hello
I want to build carrera based amp with channel switching and without reverb circuit,can you check the schematic,I would like to know your recommendations.
Cornford Carrera
Cornford Carrera
Re: Cornford Carrera
Power supply looks a little overfiltered. The breakout jacks posing as a loop could use a buffer/gain stage.
P.S. the second triode should be labeled V1.
