Signal generator question
Oddvar R
Post by Oddvar R »
I am thinking about buying a signal generator to use with my oscilloscope, to be able to trouble shoot tube amps. Is there any advice on what to buy? As cheap as possible?
Re: Signal generator question
Phone app and Bluetooth adapter.
Oddvar R
Post by Oddvar R »
Ok, that's a good tip. What bluetooth adapter?
There are many options. Just google "Bluetooth audio adapter". You'll also need a 1/8" TRS (stereo) to 1/4" TS (mono) plug adapter.
A real signal generator (the cheap imports) costs the same as a Bluetooth module. I use this one, and like it:
https://www.ebay.com/itm/DDS-Signal-Gen ... ondition=3
The Bluetooth adapter doesn't need to be anything fancy. There are many under $10.
wpaulvogel
Post by wpaulvogel »
I just use a 3.5mm to 1/4 inch cable.
Oddvar R
Post by Oddvar R »
xtian wrote: Sat May 16, 2020 4:15 pm A real signal generator (the cheap imports) costs the same as a Bluetooth module. I use this one, and like it:
Thanks guys, I think I'll try both phone and the DDS. Only problem these days is that the mail worldwide is taking an unprecedented long time.
