Has anyone Ever tried to sub a 12AV7 in place of a 12AY7?
I built a 5E3 Deluxe a while ago but didn't have a Y for V1 so I put in a 12AX7 instead and put in a Blackface tone stack to tame the extra gain. It sounds okay but not right. So I was going to buy a brand new JJ 12AY7 from Antique Electronic Supply and use the X to make channel 2 into a distortion channel. But while I was browsing around I found a couple of NOS 12A tubes that got me to thinking. the 12AV7 has nearly the same gain as the Y but is asymmetrical with a bit more gain on the 2nd triode, (which would be the input stage on my distortion channel.) They also have the 12AZ7, which is close to a T in gain.
So I thought that if I used the 12AV7 as V1 and used the 12AZ7 in the high gain channel, I could have NOS tubes throughout my preamp and it'd only cost a buck or 2 more than the new-production JJ 12AY7. The bonus is that if the Z doesn't have enough gain for my taste I could drop in the X and find a use for the Z later.
Thoughts?
ALternate NOS tubes in classic circuits
"Dime the controls, tune to drop D and flog the strings like they were naughty,"
thetragichero
Re: ALternate NOS tubes in classic circuits
before dismantling it (terrible build quality, used the parts elsewhere) the 5e3 i made used 12av7 because at the time i had the same thought as you. seemed to work okay
nowadays i would plug the information into some of the calculators on the ampbooks sure to make sure everything is going as if expect it. at the time i just saw similar gain figures and decided it would work
If it worked for you I'm just going to do it. So far I've had good luck with NOS tubes from Antique electronic supply. I got an amperex 6cm6 and an rca 12v6 for about 6 bucks each. While they wouldn't work for classic amps, custom builds are another matter and I cant complain about those brand names.
- Leo_Gnardo
Won't hurt to give it a go. If you get a result you love, you'll have a unique tube lineup to boast about.jcool666 wrote: ↑Sun Feb 16, 2020 8:27 pmSo I thought that if I used the 12AV7 as V1 and used the 12AZ7 in the high gain channel, I could have NOS tubes throughout my preamp and it'd only cost a buck or 2 more than the new-production JJ 12AY7. The bonus is that if the Z doesn't have enough gain for my taste I could drop in the X and find a use for the Z later.
Thoughts?
I bought a couple of NOS 12AV7 many years ago thinking they'd be an acceptable substitute for other 12A?7 tubes. My ears told me they are not. I don't have a technical background, so I'm not able to explain this very well. If you look at the data sheets, you'll see the 12AV7 has a plate resistance that is much more like a 12AU7. I believe the gain factor is only part of the picture. Ra is the other. The 12AV7 isn't really a close match to the 12AY7. The JJ 12AY7 is a $14 tube plus shipping. I suggest, if you've come this far, get the proper tube for the circuit. If you want to use the 12AV7, you'd probably benefit from a different cathode resistor and bypass cap choice. Of course, if you plug it in and you like it, that's good, too!
After taking a closer look at the datasheets I saw that the plate current, plate resistance and transconductance more closely match the T instead of the Y. I'm now starting to wonder if you couldn't use a V as a cathodyne phase inverter. That might be something I'll play around with, but not in this amp. the phase inverter works and I don't want to mess with it.Phil_S wrote: ↑Mon Feb 17, 2020 8:51 am I bought a couple of NOS 12AV7 many years ago thinking they'd be an acceptable substitute for other 12A?7 tubes. My ears told me they are not. I don't have a technical background, so I'm not able to explain this very well. If you look at the data sheets, you'll see the 12AV7 has a plate resistance that is much more like a 12AU7. I believe the gain factor is only part of the picture. Ra is the other. The 12AV7 isn't really a close match to the 12AY7. The JJ 12AY7 is a $14 tube plus shipping. I suggest, if you've come this far, get the proper tube for the circuit. If you want to use the 12AV7, you'd probably benefit from a different cathode resistor and bypass cap choice. Of course, if you plug it in and you like it, that's good, too!
