Lowering Negative bias voltage
RWood
Post by RWood »
I have been given a set of Transformers from a 1965 Sansui 1000a. I'm attempting to put them to use in a 40ish watt 6L6 amp. It has a 32 v tap (unloaded) which I fear will be too low for 2 6L6s. Sansui used that tap to get -19 volts for a quad of 7591s. I made up a doubler that gives me around -80v which is too high. The bias pot bottoms out at -48v. My question is...Should I use a dropping resistor after filter which feeds the bias pot or before the doubler...or something else?
I put a 9k1 resistor in series just before the bias pot and got -24v to -68v unloaded. I've never tried this implementation before and was wondering if there are any pitfalls before I build the rest of the circuit?
If it don't get hot and glow, I don't want it !
roberto
Re: Lowering Negative bias voltage
Post by roberto »
Do it, it’s ok but take care of the maximum current of the tap.
And reduce the range of the bias by one order of magnitude.
PS
when talking about negative values, lowering a value means increasing its module and so male it even more negative. This is for your next posts.
