CTS Pot Taper
Littlewyan
CTS Pot Taper
Post by Littlewyan »
I've just built an amp and used CTS Pots across the board, but I have to say, I'm not impressed with the audio taper at all. On the volume controls, between 0 and 1.5, nothing happens. Then above 1.5 the volume will ramp up quite quick, which makes it difficult to get a good volume for bedroom playing. Is this the norm for CTS pots? If it was nothing between 0 and 0.5, I'd understand, but this seems like a large area of taper to lose.
wpaulvogel
Re: CTS Pot Taper
Post by wpaulvogel »
Measure the resistance and make sure you didn’t get linear. I’ve used CTS on several amps and they work great.
Littlewyan
Re: CTS Pot Taper
They're definitely Log Audio, they just don't seem to come on until the volume control is at 1.5 from 0 (Control goes to 10). Have you found this on your amps?
Re: CTS Pot Taper
Based on a few Googles, the CTS audio pots seem to have that characteristic.
pdf64
Re: CTS Pot Taper
Post by pdf64 »
What pots don’t? Seems standard / typical to me. Electrical rotation is generally 10 to 15% less than mechanical rotation, eg 240 / 270. And with the cheap pots we use in this application, it’s invariably an untoleranced characteristic.
Littlewyan
Re: CTS Pot Taper
I found an old post where someone compared various pots and you're right, it seems CTS do have this characteristic. Alphas appear to be better in that they do come on sooner, so I may switch to those. I have used them before in other amps so will do some tests on those first.
I realise I can't expect new pots to come on as gradually as pots from yesteryear, but having nothing between 0 and 1.5 (would actually maybe say it's more like 1.8) is a real pain for getting a bedroom volume on the amp.
Guy77
Re: CTS Pot Taper
Post by Guy77 »
Littlewyan wrote: Thu Dec 26, 2019 12:54 am I found an old post where someone compared various pots and you're right, it seems CTS do have this characteristic. Alphas appear to be better in that they do come on sooner, so I may switch to those. I have used them before in other amps so will do some tests on those first.
I have experienced the same thing as you have with the CTS audio taper pots coming on a little later than the alpha pots. At first I thought it was a defective pot but then after going through about 10 cts pots from 4 different sources I realised it is just how the cts pots are built.
What I do now is just use alpha pot for my volume and master volume and cts/alpha for other controls.
Happy Holidays!
Guy
pdf64
Re: CTS Pot Taper
Post by pdf64 »
Maybe the CTS track is intended to also accommodate the incorporation of a rotary switch actuating at full CCW.
Littlewyan
Re: CTS Pot Taper
Possibly. Cost cutting maybe?
It sounds like my best option is to just replace the volume pots with alpha pots. I did look at PEC, but they are incredibly expensive and don't appear to be all that reliable going by some reports I've read.
Thanks for your responses guys.
