Bad Cat Deluxe goes BZZZT when switching on
jaymann
Post by jaymann »
A friend brought by a gorgeous Badcat Classic Deluxe for me to check out and it makes a weird electrical buzzing noise when you flick it off standby.
Any thoughts on what this could be. It sounds like something out of young Dr. Frankenstein's lab.
Re: Bad Cat Deluxe goes BZZZT when switching on
Failing standby switch.
tubeswell
Post by tubeswell »
Bad cat with the insanely high EL84 voltages? Maybe failing EL84s?
jaymann
Post by jaymann »
6V6 power tubes and a GZ34 rectifier
frankdrebin
Post by frankdrebin »
standby in GZ34 amp? useless and detrimental for the tube itself.
It can be arcing inside the switch or a tube,or a socket.
Post by Stevem »
Since you can not come up with the 4 possible things that could be making this issue and neither can the owner of the amp then it needs to be taken to a amp tech before more possibly harm takes place.
Leo_Gnardo
Post by Leo_Gnardo »
At first I was gonna ask, does the Bzzzt diminish with time, or stay more or less constant. After seeing the video, sounds as if it's constant.
Could be simple as unmatched output tubes. OR perhaps an open screen grid resistor, or sg resistor burnt to the point it's off spec. Failed filter caps also come to mind. Yes, it would be good to "seek professional help."
