Schematic needed for WHE707 Way Huge Supa-Puss delay
wpaulvogel
Wondering if anyone has a schematic for this delay. really just need value for R79.
Re: Schematic needed for WHE707 Way Huge Supa-Puss delay
You know those are all SMD components, right? Not sure if you're trying to repair/modify an existing one, or build one. If the latter, there are other pedal-focused forums that might be more appropriate.
EDIT: For shits and giggles, I googled a little and found your post on another forum. If it's any help, I can crack my Supa-puss open and get a pic for you. Likely your best bet is to call 'em up. I had them do some warranty mod work to mine, and they were super cool...
Hope that helps.
Hope that helps.
I know it's only rock and roll, but I like it!
Related or unrelated, you choose. I played a Supa-Puss, and Aqua Puss, and they were OK. Then I played an Ibanez Echo Shifter. LOVE IT. So awesome, so inexpensive!
https://reverb.com/marketplace?query=ib ... rice%7Casc
wpaulvogel
Thanks guys,
I took a shot at it and turned out that he damaged the SMD pad. I couldn’t do anything with it. Too small. He’s probably going to send it to Way Huge.
- Gainzilla
I've always wondered about those. You don't see them very often, and the design looks kind of unique. I chased delays for quite a while, and still do GAS for anything that will repeat, but the one that stays on my pedalboard is the Vox Delaylab. It's ugly as F*#k, but it sounds amazing, not only for the way the models sound, but particularly in how it handles the dry signal. Your core tone is just always fully there. Also, It's got 4 presets and multiple banks, as well as some cool modulation effects. I dig it. Can be had for less than $150, too! Might pick one up as a spare. Kidding... Mostly...
