Peavey 6505 plus schematic
Post by Stevem »
Anyone got a preamp schematic for one of these pups?
The one I have has hiss like it's going out of style emanating from V1 and I have swapped out both plate load resistors with no improvement, and yes it's not the tube!
Thanks in advance !
Lauri
Re: Peavey 6505 plus schematic
Post by Lauri »
If I remember correctly Peavey 5150 II schematic is exactly the same as 6505 plus
https://www.thetubestore.com/lib/thetub ... ematic.pdf
Post by Stevem »
Thanks for your time and input , but the 6505 has 6 preamp tubes and the 5150 has only 5 .
sluckey
Post by sluckey »
If you call the tech service or repair department you can probably have that schematic within the hour. Peavey folks are friendly and very accommodating.
https://peavey.com/support/contactinfo/
frankdrebin
Post by frankdrebin »
Stevem wrote: Tue Jan 15, 2019 5:24 pm Thanks for your time and input , but the 6505 has 6 preamp tubes and the 5150 has only 5 .
6505 is the 5150,6505+ is the 5150 II,simple as that,schematic is around the net.
They had just changed the name because of EVH trademark.
The combo is different though.
tubefix
Post by tubefix »
Please correct me, if anyone solved the hissing problem with the 6505's. But I guess it's quite normal, lots of tube stages. -_-
Don't touch it if it's hot!
LOUDthud
Post by LOUDthud »
Using the schematic linked in post #2 above, if it has that 68K (R22) on V1A, install a short.
tubefix
Post by tubefix »
so, then you will have russian radio on your amp. Why do this?
Post by Stevem »
What helped out in that one I was working on was changing out that 68k for a good quality 1% 2 watt metal film.
