Roe wrote: ↑Tue Jan 08, 2019 8:05 am
yes, it is shielding and it works well. Fender even shields the speaker output jacks on newer amps
Are you talking about the thick insulating board they fit around the two speaker jacks? If you notice where the jacks are located in the chassis, often they are positioned near high voltage nodes and those are there to prevent anyone (children, etc.) from inadvertently sticking something in the speaker input and potentially shocking themselves.
you wrap the jack in electrical tape, then foil with a ground wire, then a big shrink thing. The ground wire and the wire shield go to the input ground.. you use smaller shrink butted up to and over the larger stuff to cover the wire tail made at the junction of tye jack and wire.. it looks like a real rat tail.
Reeltarded wrote: ↑Fri Jan 18, 2019 3:56 pm
I can visualize it RT.
But what about the "shrink wrap".
Can you link a source for what you're talking about there
Reeltarded wrote: ↑Fri Jan 18, 2019 5:51 pm
At hardware stores I shop at they have it up to I think 3.25 inch (1.62 wide?) Electrical supply sites I have browsed also had thick and wide shrink.
