Best Way To Clean Metal Surfaces Inside Amp Chassis
Cathode Ray
Post by Cathode Ray »
I'm thinking rubbing alcohol and cotton pads, but is there a "best" way to accomplish this without leaving residue/smearing :?:
Thanks :!:
tubeswell
Re: Best Way To Clean Metal Surfaces Inside Amp Chassis
Post by tubeswell »
Isopropyl alcohol and elbow grease works for me.
If its rusty, a steel wool pad or fine grit sandpaper inside the chassis doesn't do any harm
Tony Bones
Post by Tony Bones »
If it's a bare chassis then put it in the sink with some hot soapy water. If it's just an old amp that I'd like to clean up a little, then I either (a) leave it alone, or (b) spray it down with deoxit. The deoxit is an expensive solution (no pun) but I know it's safe.
If it's a blank chassis in the sink with ammonia and if it's some old amp I take it to a coin op laundry.
Just kidding. I don't clean old amps innards.
Cathode Ray
Thanks guys!
Reeltarded wrote: Thu Dec 06, 2018 12:46 pmJust kidding. I don't clean old amps innards.
I hear it cuts down on the "mojo" if you do. :roll:
Funk Factor.
I actually use some stuff called "Unky Funk's Tude Loob". Has a picture of Bootsy Collins so surprised you can see his eyes. It's made of BBQ pork lard in a aerosol. Also available in roll-on and suppository. You can buy in on Amazon with a medical weed scrip... or grow a can yourself in 6 states. (so far)
roberto
Post by roberto »
It depends on what the dirtyness is, and partially on the metal itself.
Cathode Ray
Reeltarded wrote: Thu Dec 06, 2018 7:04 pm Funk Factor.
I usually put that on mah strings. :roll:
