I have all the makings of several MXR phase pedals, so I would like to try to bypass the phasing section of the Music Man circuit board, and add a Phase 90 phase section daughter board into the amp.
Basically, I would take this circuit:
and jack it in to replace this part of the Music Man circuit:
What I don't know is quite how the difference in bias voltages will affect the JFETs. I don't think there too much voltage (the Music Man supplies +16 and -16), but I don't know if this will get the JFETs moving right to start phasing.
I'm also not clear on how the Music Man powers the opamps. Before I disconnect I will check to see if there is voltage on pin 8 of the JRC4558s I have in there. The schematic doesn't show any connections to these opamps. But in other Phase 90 schematics, I see the opamps powered at 9v.
If anyone has the patience to read through this mess, any thoughts on this endeavor is appreciated! I will update as I move along.
BTW, I did consider just sticking an FX loop in the amp and running a phaser pedal...which would make way more sense. But I want to be able to use my Music Man with an onboard phaser. I know that is completely illogical. So be it.
