Hey guys. I just recapped my 212-75. All electrolytics were replaced. The only discrepancies were the two 400mf 25v caps. I replaced one with a 420mf and the other with a 440mf. Also replaced both driver transistors.
When I powered her back on, I got nothing but a loud hum. One power tube began quickly red plating. I'm not sure how to proceed. Can I take out the power tubes and power it on without hurting anything? That way I could look at voltages without destroying my tubes. Any advice?
https://www.thetubestore.com/lib/thetub ... ematic.pdf
Recap Problem
- Tony Bones
Re: Recap Problem
Maybe one of those electrolytics got installed backwards?
Re: Recap Problem
Yes, I believe you can. Look for a little under 1V on C47 with TR1 centered, a little less than half of that on both of the transistor bases, and 22V on the power tube grids. You’ll need to have the power tubes installed to see where the cathode voltages settle, but maybe after checking the grids and base bias voltage you could power up just long enough to get a reading. They should be in the mid 50’s, I think.hossymandias wrote: ↑Sun Nov 25, 2018 1:51 pmCan I take out the power tubes and power it on without hurting anything? That way I could look at voltages without destroying my tubes. Any advice?
hossymandias
Re: Recap Problem
I got it. One of the new transistors was shorted at the collector. All sorted out now. Thanks guys! BTW, I was able to pull the power tubes and power on no problem.
Re: Recap Problem
Great!
