I want to add a solid state FX Loop on my amp.
I would like to mount the board directly to the send/return jack rather than to place the small board separately on the chassis by narrowing the space.
Is there a 1/4 "jack that can be mounted directly on a 2.54mm(0.1") hole-spaced perfboard?
Are there any 1/4" jacks that can be mounted on perfboard hole spacing of 2.54mm(0.1")?
psychepool
- pompeiisneaks
- Site Admin
Re: Are there any 1/4" jacks that can be mounted on perfboard hole spacing of 2.54mm(0.1")?
are you looking for something like the cliff jacks part way down the page here:
https://hoffmanamps.com/MyStore/perlsho ... D=!ORDERID!
they have pins so they'd go into a PCB instead of being soldered to like the oens above (PC Lug style)
~Phil
~Phil
tUber Nerd!
Very little is impossible to one who has wire, solder, an iron, and a tube of five minute epoxy.
A fully enclosed jack can be neatly epoxied down on its side to a bit of perfboard.
Mark Twain
Mark Twain
