Shipping box corner blocks. Source??
RockinRocket
Post by RockinRocket »
Any one know where I can buy those corner blocks for amps that every major brand uses to pack there amps??
These are the only thing I really trust to protect an amp during transit. They compress and absorb impact. Easy to use. 8)
Re: Shipping box corner blocks. Source??
Can try Uline that's where a lot of business get their boxes from and other supplies.
https://www.uline.com/Grp_93/Insulated- ... d-Supplies
https://www.uline.com/BL_2154/Foam-Protectors (Corners)
RockinRocket
Thanks Mark. Searched a bit there and this should be the stuff everyone uses.
https://www.uline.com/BL_868/Plank-Foam ... =Foam+Core
To use 4" on all sides/corners of a amp and 2" thick will cost 25$ in raw material.
You would have to use at least 6"+ thick of bubble wrap for the same shock protection.
Hey that does look like what you could use, just took a little more searching.
https://www.uline.com/Grp_165/Edge-Protectors
I was thinking the OP was asking for something like this. I don't see any reason why these couldn't be placed inside the box, strapped or fitted to the cabinet or whatever. I bought a new gas grill about 2 months ago and they used these inside the box. I saved them. There are unlimited good uses for them.
RockinRocket
Phil while those corners are great at strengthing a weak box you really want to protect amps from drop impact.
The shipping industry is absolute garbage in care of handling. Box are dropped, tossed, stepped on ect..
