Hi Folks, A friend of mine needs an attenuator for his 61' Fender Concert with a 2 ohm output trans. 2ohm attenuators are pricey and I figured I could wire up a cheapy with some old parts I have laying around.
I have a few questions about Power handling of L-pads/Rheostats. Would a 75W Rheostat be enough power handling? I know a 100W Rheostat would work but I can only find a few online bidding sites selling NOS units that don't have a shaft to attach a knob. mouser/digikey only have 50w units for 100$cad. what if I found a 100w dual ganged 4 ohm rheostat, couldn't we just wire the gangs in parallel to achieve the 2ohm load I need? I plan to make a basic one with a brite switch and bypass switch so my buddy can enjoy his concert to its full potential.
2 ohm DIY Attenuator
Re: 2 ohm DIY Attenuator
I would guess yes, unless he plays punk music flat out. Fender concert puts out 40 watts clean?
Rockwell666
ya they say 40W clean but at 500v on the plates its prob doing closer to 50W. I feel the 75W rheostat with alittle caution and maybe a fan for cooling would be fine. I just wanted to see if anyone had any experience. the 2ohm attens are crazy expensive
You can also use the standard 8 or 16 Ohm attenuator you and/or your friend already have/has and then add an impedance adaptor between the amp and the speaker.
How much attenuation is needed? Does it have to be adjustable? Play around with this to see how much power is dissipated by the resistors in an L-pad: http://www.tedweber.com/webervst/lpad.htm
Fenders 'EC-series' of amps uses simple 25W cement resistor and switch combinations between the OT Secondary and the Speaker for power attenuators.
The EC tremolux (with a 25W 8R speaker) has a 8k:8R OT with 2 resistors and a DPST switch for full power or 1/4 power attenuation. The '1/4-power' option puts 8R in series with the 8R speaker as well as 16R in parallel with these - to keep 8R overall.
Similarly, the EC twinolux (with 2 x 8R speakers in parallel) has a 4k:4R OT with 3 resistors and a douple-pole 3-way switch for full power or 2 attenuation options.
For a higher power amp with a OT with 2R secondary, (e.g. a BFTR) a you could do either type of attenuator using the same resistors with more resistors added in parallel to get increased power dissipation and decreased resistance.
I have to say that pure resistance attenuators always sound artificial to me.
IMHO this is still unbeaten:
