Hi Guys,
Looking for a circuit diagram for this unit. Apparently a chip has failed. Would love to get it going.
MORLEY analog echo reverb
andresound
If it sounds good, it is good! Trust your ears
Re: MORLEY analog echo reverb
Clearly you didn't try Google...very easy to find ...
A lot of these old chips are hard to find in new stock , and many times when you do find one in old stock the price is so high, or they have 25 pice minimum order that you end up forgetting the whole idea of restoring it!
Does it work at all even in bypass?
This is a great forum for effects. I'm sure someone there has the old chips to help get it working again...
http://www.freestompboxes.org/index.php
andresound
I did find this... Not very clear
andresound
Was this a good sounding unit? Looks very well made
There's a ton of electrolytic caps in there that can flat out fail , or go leaky enough to to make it act dead!
It reminds me of the mid 60s SS Vox amps , but with chips!
andresound
Thanks Stevem. I will check those first.
