Good evening all, I have a Lowrey organ Schumacher output transformer P-6051 606-910 that used 2-6v6 power tubes pp. I presume it has an 8k primary but does anyone know what the speaker load is supposed to be?
Thanks for any help, Andrew
lower/schumacher OT
Re: lower/schumacher OT
You won't know unless you test it. Knowing it was running a pair of 6V6 is very useful because it tells us it is rated in the 15-18w range. It is easy enough to test the turns ratio. Instructions are here: http://www.sarris.info/main/calculating ... -impedance
I generally use the output from a filament winding to do the test.
Looking that part number up in my 1958 electronics catalog states it made for a 8 ohm load.
Thanks guys.
