I am on the verge of starting a PCB layout for a fixed bias VVR Board. This came out of a conversation I had with strelok in a separate thread he started a few weeks ago. Strelok and I (mostly strelok) have been working through this design, and we thought it would be a good idea to open it up to the forum and start a discussion that might improve the design's operation and functionality. My goal is to do a layout that will be small enough to mount to the front panel by way of directly soldering the board to a dual-gang panel-mount potentiometer. I realize that heatsinking of the B+ MOSFET will be mandatory, and the intent is to mount the MOSFET close enough to a board edge such that the MOSFET can be bolted to the chassis for heatsinking. There will also be a 0.125" mounting hole in each corner of the board, in the event it is not practical to use a direct-solder pot. In the interest of making the board small enough to comfortably hang off a direct-solder pot, I may have to delete the Bias supply components R7, D5, R8, C1, and C2. If that is the case, I will do a layout for a small Bias Power Supply Board. Once the design is tested, I will make the board(s) available at a reasonable cost - this will be just the pc board, the buyer will need to source their own components and assemble the board. To that end, I will make a BOM available that will include manufacturer's as well as Mouser part numbers.
A cathode bias version will also be made available once the fixed bias version is in production.
If you have any feedback on the design at this point, please don't hold your breath.
Many thanks,
Lou
