Source for Fixed Bias VVR Boards
strelok
Post by strelok »
Does anyone know where I can get some? I seem to remember someone on here was thinking about making and selling them a while back but I don't remember who. Would like to buy a few for my latest and upcoming builds.
JazzGuitarGimp
Re: Source for Fixed Bias VVR Boards
Post by JazzGuitarGimp »
Hi Strelok,
I think you are thinking of me. When this question came around last time, I had suggested that if someone wants to provide me with a schematic and BOM, I would be happy to do a layout and provide boards - but I don't think anyone responded to my offer, which still stands, by the way. Though at this point, I'd need two to three weeks to get the boards back from the fab house.
Lou
strelok
Post by strelok »
Cool thanks, any idea how much each board would cost? Would there be a minimum order? I'll see if I can come up with a schematic and parts list that would be suitable.
mhartman
Post by mhartman »
I've always just wired up the "VVR" circuits using a home made eyelet board. The circuit is very straight-forward.
JazzGuitarGimp
strelok wrote: Wed Apr 05, 2017 4:29 am Cool thanks, any idea how much each board would cost? Would there be a minimum order? I'll see if I can come up with a schematic and parts list that would be suitable.
PM Sent
Kagliostro
Post by Kagliostro »
A member of DIYItalia had some experimentation with Merlin's VVR for fixed bias, he tried to use it on a Marshall, but had problems
related with the source of the voltage
reading on LondonPower site seems that a low impedance supply is required (a separated transformer)
here a bit of documentation if someone want to give a try
Franco
MakerDP
Post by MakerDP »
You also need a tracking circuit to adjust the bias voltage as you adjust the B+ voltage.
Kagliostro
Is the low part of the schematic
The sensing input point is labeled "dal nodo alimentazione G2" on the schematic
Franco
andresound
Post by andresound »
Don't mean to hijack the thread, but I ordered VVR boards for Cathode bias from Hall about 6 months ago. Still waiting!!! Does anyone know if he is still around?
If it sounds good, it is good! Trust your ears
Kagliostro
On the red rectangle the whole circuit
On the blue rectangle the Bias & "Bias Sensing" circuit
The red cap was added by Merlin because of some cases of auto oscillations of the circuit
You can use the Top circuit (without the Bias & "Bias Sensing" part) for Cathode Bias Amps
(the advantage of this circuit is that a common pot can be used as there is a lower voltage on it)
...... I ordered VVR boards for Cathode bias from Hall about 6 months ago.
Have you tried to write an e-mail to Hall ? Are you sure they received your orther ?
Franco
andresound wrote: Thu Apr 06, 2017 8:06 am Don't mean to hijack the thread, but I ordered VVR boards for Cathode bias from Hall about 6 months ago. Still waiting!!! Does anyone know if he is still around?
Yes Dana Hall is still around. You should contact him again and see what's up.
andresound
Thanks Mark. I know we have a REALLY slow postal system, so wanted to give Dana the benefit of the doubt
