There are 2 cap cans, that are the paper Astron type. I've never seen one of these in person, but the ends appear to be bulging out. There was apparently some repair work done in the past, where 2 radial caps were jumpered across the bottom cap can. There wasn't any such work done on the top cap can.
I've circled where the ends are bulging out. Are these defective at this point? The 2 radial caps should take care of the filtering, but will the cap can still being in the circuit cause a safety issue?
Also, there is a cap from the power switch to ground. This has the 2 prong electrical connector. What does the cap do?
Lastly, my friend wants the 2 prong connector replaced with the modern 3 prong variety. The current cord is pretty skinny, and the chassis hole for it is fairly small. Where can I find a suitable replacement that will fit without drilling?
