6AK5 - 5654 Tube - Someone has experience with this tubes ?
Kagliostro
Post by Kagliostro »
I know this VHF tube was used in some tube microphone also if originally it was not planned for this use
http://www.r-type.org/exhib/aaa0122.htm
https://frank.pocnet.net/sheets/049/6/6AK5.pdf
Telefunken V72
Someone of you has tried it in guitar amps ?
Franco
Re: 6AK5 - 5654 Tube - Someone has experience with this tubes ?
Post by Stevem »
How many of these tubes do you have ,if only 3 or 4 I don't know that I would do a build based on them unless I included the flexibility to change over to something else without major work, but hey it's your time input!
10thTx
Post by 10thTx »
Hi K,
DaGeezer (on the Hoffman forum) and I experimented with them yrs ago & I think it was on a dual pentode idea for a HoSo56 but it's been so many yrs that I don't remember which amp for sure? We each tried them out on the individual amps that we had and had similar results that we reported.
What we did is wire up a V1 socket with 5879 and then paralleled another socket (in the preamp V1 position) to use either 6AU6 pentode or 5654 pentode (which I think have the same pinout?)
It was a fun project. You could use the 5879 alone, 5879 with 6AU6 or 5654, or the 6Au6 alone or the 5654 alone. This allowed me to try all three of those tubes in a V1 position. IIRC, I liked the 5879 best, then the 5654 next and then the 6AU6. I remember it being a nice sounding tube in a V1 position for whatever amp that was that we tried it out in?
Some yrs later, I tried the 5654 in place of the 6AU6 for a vibrato similar to the Silvertone 1482 or Dan Electro Centurian 275. It worked well as a vibrato tube in that design also.
You can look up the data, but IIRC ............ I think the 5654 needs somewhat lower voltage?
With respect, 10thtx
10thTx
Post by 10thTx »
Found this quote from DaGeezer on the Hoffman forum
6AK5 is same as 5654 (which is the military version). I use them (5654) as V1 in some of my amps....fantastic tube & NEVER had one go microphonic
And this was a quote from me on the same thread
Also what worked was the 5654 but read the specs because the maximum voltage is more limited. It was a good sounding tube to me.
Ah, found the schematic referring to the amp design I was talking about.
Kagliostro
MANY THANKS 10thTx
I know Da Geezer works (and your's), they are very fine
... I tried the 5654 in place of the 6AU6 for a vibrato similar to the Silvertone 1482 or Dan Electro Centurian 275. It worked well as a vibrato tube in that design also
This was new to me, thanks
I was looking if some other people experimented with those tubes (I think I've a pair of schematics where the 6ak5 were used in audio)
No other people has experience with this tubes ?
K
