Speaker ID
Smokebreak
Speaker ID
Post by Smokebreak »
I busted out my childhood amp today, a '71 Super Reverb, that I used in my Rocknroll days in the early 90's. Back then I turned it all the way up. It's a glorious sounding amp that had been modded by the local guru back in the day, which essentially is push pull pot that places a large cap over the treble cap and also reduces the 3M3 a bit. Great mod. Anyways, I haven't used it in years, because I have no patience for hauling around a 4x10. My plans are to put it in a 2x10 combo, and get two 4ohm speakers, and put it to use again.
So I was playing it today, and it sounds great as ever, and I got to wondering about the speakers. The cones have 45105-2, and an the side of the magnet w/ black frame is a white sticker that has 55-715.
Some quick googling tells me Eminence, but that's all I really know.
Does anyone know what these speakers were, and what, if any, were they replaced with in the newer Eminence line? Or maybe what speakers are similar? Here's a picture of someone else's that I believe to be the same. They sound fantastic. Very warm, articulate, punchy. All the speaker buzzwords in one ;)
Re: Speaker ID
Post by Stevem »
Can you post up a picture of the white sticker?
Leo_Gnardo
Re: Speaker ID
Post by Leo_Gnardo »
You can ask Eminence, go to their webite & pitch your query. Couple years ago they had a guy on staff who was sorta the speaker "concierge", took all kinds of questions from the public & gave good answers. Of course that had to end, but afaik Emi's still good about answering, and only keeps secrets of "proprietary" custom-ordered speakers otoh they'll direct you towards which available speakers most closely resemble the custom jobs.
Smokebreak
Re: Speaker ID
Ok cool , thanks Leo, I'll give that a shot. STeve here's the sticker
tubeswell
Re: Speaker ID
Post by tubeswell »
I see a 67 - that's definitely Eminence
Re: Speaker ID
Post by Stevem »
Yup,Eminence!
Post up a picture of the cone side and I can then tell you what would be close for a replacement.
Smokebreak
Re: Speaker ID
Ok great, I'll take some pics and post them up once I get into the conversion.
Re: Speaker ID
Post by Stevem »
I contacted Eminence once with info from one of there tags from a speaker with a massive 95 oz mag made in the mid 80s and all they could tell me was that it was likely rated for 300 watts.
Smokebreak
Re: Speaker ID
Here's the front view, Steve
Re: Speaker ID
Post by Stevem »
Ah yes! The Eminence version of the ELectro Voice SRO model , but with a 5 rib cone !
As far as I know there is nothing off the shelf for this in the Eminence line right now , but for the swap thing driver with its big 150 watt voice coil, but it does not have the same cone, but I will look again for you.
Weber makes something that is close, or can make your something near dead on, or you may beable to turn up a used Mesa Boogie black shadow speaker which was real close to the EV driver.
Smokebreak
Re: Speaker ID
Ok great! So these would be Emi's version of the ceramic SROs, which were essentially EV12Ls, correct?
I see weber has a Michigan, both Alnico and ceramic, which look like they are Weber's EVs
Re: Speaker ID
Post by Stevem »
Correct!
