Tube distortion pedal
Behringer Vintage Tube Monster VT999 at Sweetwater for $49.99
The only thing I had to do was do some tube rolling. Dam good sounding pedal after you choose a good tube.
Did some tube rolling:
Telefunken ECC83 was warm good sounding
Ruby 12AX7AC5 was brighter with good distortion
JJ Ecc83 MG was terrible squashed sounding
JJ Ecc83 S was very good sounding
Tungsol 12AX7 was the best high gain tube of all of them KEEPER
Sovtek 5751 was the tube I did keep in the unit because it's lower gain and articulation
Re: Tube distortion pedal
Thanks for the review, Mark! That's a marvel of miniaturization.
What's the plate voltage?
Is it powered by 9vDC or what?
And finally, can you tell how much DC current the rig is pulling?
studiodunn
Post by studiodunn »
I see room for additions :D
Thanks for the heads up. That looks like a great deal.
xtian wrote:Thanks for the review, Mark! That's a marvel of miniaturization.
I didn't even think about all those things so I will take some measurements.
The unit comes with a 9v wall charger which could be run through a charge pump I don't know.
dcribbs1412
Post by dcribbs1412 »
Found a mod for this pedal if interested
It starts as a VT911 mod but it turns out its a Vt999 mod
supposedly tames some harshness, probably same as using a 5751 tube
http://www.freestompboxes.org/viewtopic.php?f=11&t=3113
D
Cool thanks.
The pedal can have some harshness, especially with the supplied Behringer valve that came with the pedal. I also experienced some harshness with two other valves.
deeder
Post by deeder »
You can give a try to a JAN 6072A GE black plate (12AY7).
http://www.ebay.fr/itm/142261687381?_tr ... EBIDX%3AIT
gktamps
Post by gktamps »
Thanks for the lead to this pedal, Mark. Got mine and it sounds great with my JB Strat into my lower-gain Rockets. Lotta pedal for the money. Haven't even rolled tubes yet.
The pedal is useful to get a nice tube distortion on a budget.
I took another look around inside but too tight for me to mess with taking voltage reading.
Malcolm Irving
Post by Malcolm Irving »
Looks like great value.
I love the way the advertising says the 12ax7 is ‘hand selected’. I guess that means the assembly worker has a box of tubes under the bench and puts their hand in to select one! :D
