Classic tone 15watt OT
menger66
Post by menger66 »
I want use my CT se champ 15watt ot in my next project with a 5881 @ about 380 plate voltage IT has 5k and 8k PRI with 4 ,8 ,16 ohm taps in using a deluxe size PT, which primary would work best with the 5881. Thanks mark
N
Post by Stevem »
Let me tell you how to find out, go to the Duncan amp site and look under tube data for your 5881 , there you will find the info you need under the begining SE section.
Off the top of my head I think 380 volts is too high for SE!
Re: Classic tone 15watt OT
What you want for center bias at that plate voltage is 6k3 (100% dissipation, 23W), with screen voltage about 100V less than the plate. I think the 5K would work fine, though.
