Thanks guys! I really appreciate it!
The guitar was dyed with red aniline dye. Its swamp ash which is an open grain wood, so it needs to be filled with some kind of grain filler. This is basically the steps I went through to do it, there are other methods that require less work but this is the cheapest and doesn't require a spray gun.
-Standard wood prep, sanding etc (mine was from Warmoth so it was already sanded.)
-Raise the grain. I used a water based dye so you have to lightly wet it and sand several times so it doesn't raise up when you apply the dye.
-Apply dye
-Seal the dye in with several coats of clear spray shellac
-Prep the filler. I used drywall putty thinned out with water and mixed up with black aniline dye until it was pitch black.
-Apply the filler. Wearing latex gloves just slop some onto the body and rub it in. Do a section at a time, wait a few minutes to dry and scrap off excess with plastic putty knife.
-Sand down until just the pours in the grain have filler left in them being careful not to go through the shellac.
-Once you have the whole body done probably will have to repeat a few times to get it completely filled as it shrinks as it dries.
-Once filled seal again with a few coats of clear spray shellac
-Apply necessary coats of clear, level sand if necessary and repeat. Wait to cure.
-Wetsand progressively up to 2500 grit or so. Buff with polishing and rubbing compound.
Its a hell of a lot of work, the open grain woods double the amount of work you have to do if you're going for that transparent grain filled look, but I think its worth it. Here's the full tutorial I followed if anyone is interested:
http://www.tdpri.com/threads/swamp-ash- ... al.371080/
For the amp I agree pine isn't the most interesting wood, but its cheap and I'm on broke as hell
Given the limited tools I had access to I think it came out pretty good. The cool thing about using shellac for the color is it does bring out what grain is there and it adds a bit of a flame effect you might not see with other stains etc. Its not a strong finish so I added some clear coats over the top to help protect it.
One other thing I will add is I don't recommend using Duplicolor Acrylic Lacquer for clear coats. For whatever reason the stuff takes absolutely forever to fully harden. Especially when using a lot of coats like I did on the guitar. It dries quick but its a known issue with regards to how long it takes to harden that I only found out about afterwards.
