Is a long time I'm looking for documentation of commercial amps that uses a Tone Control after preamp pentodes (usually only a rotary switch with caps is used)
Recently I've find the Ampeg Duette Preamp schematic that uses a Treble + a Bass control after a 6SJ7
[img:5607:3967]http://i.imgur.com/nb1ShUd.jpg[/img]
here a description of the amp
http://www.ggjaguar.com/duette.htm
This configuration is indicated as an optional, but at the end I've find a commercial amp with such a configuration
I'm not able to find the schematic of the whole amp in which this preamp was used (as optional), someone has a link to the schematic ?
Many thanks for any info
Franco
Ampeg Duette Preamp ... which is the whole amp schematic ?
- Kagliostro
Re: Ampeg Duette Preamp ... which is the whole amp schematic ?
I think that the key benefit in using a pentode pre-amp is for its high gain.
Unfortunately they have high output impedance, such that when trying to drive a medium impedance load such as tone controls, the gain would be reduced, perhaps to the point at which a regular triode may as well have been used.
Other Ampegs of that era all seem to have a very similar design of power amp, so it may be reasonable to assume that the Duette / Dolphin power amp and supply was also similar.
http://bmamps.com/Schematics/ampeg/Ampe ... ematic.pdf
http://bmamps.com/Schematics/ampeg/Ampe ... matics.pdf
Those with EL37 power tubes all seem to use an OC3 dropper for the screen grid supply, perhaps to ensure that their 400V limit is not breached.
M
A pentode preamp can be set up to add compression / sustane without clipping to a much larger degree then a triode which is a nice trate to work with!
- Kagliostro
Many thanks for answering and for the link of the schematics
Franco
Franco
