Coupling caps on the LTP
stoo
Post by stoo »
Hi everyone.
I've noticed that KF used the same value of input coupling caps on both halves of the phase inverter. (Or on several of his variations). I've notived Marshall uses .02 and 0.1. Also on the tech pages at Aiken amps he suggests the second cap be 10x the primary cap.
Any thoughts??
Stew
klingo
Re: Coupling caps on the LTP
Post by klingo »
Hi!
as the preceding stage 0,002uF/150K cap/resistor design is already cutting the bass, i think he used the big cap feeding the PI (high input impedance) to tame the high a bit...i may be wrong...
Aiken Tech pages are great!
David Root
Post by David Root »
The standard argument for the 0.1 value is to ensure the input resistor is fully bypassed, so that both inputs have a balanced low end frequency response. It's overkill but safe. It could be lower and still work OK in that respect.
Maybe KF wanted an unbalanced frequency response for some reason eg different harmonic content? Maybe he just wanted to have lower than "standard" bass response on both sides, to avoid blocking distortion at the output coupling caps?
