Now the question is what pre-amp? That was quickly answered when I came across this video:
https://www.youtube.com/watch?v=JASfKMCL6Ag
Tweed Deluxe with 6k6gt's in the output. Perfect. He loves classic rock and this nails it. From what I gather this is the stock 5E3 circuit but with .022uf coupling caps instead of .1's. Also had a SS rectifier. I was on the fence about whether or not to go tube or SS, but I eventually settled on SS as it's one less thing to worry about. I also just really like the way this amp sounds.
Aside from that and the VVR, I decided to do the input slightly different. One input jack, with a pair of 33k grid resistors feeding the grids of the first 12a*7. So its similar to having the channels jumpered on a conventional deluxe. I also decided that I will use a split cathode configuration. Normal channel will have a 1.5k resistor bypassed by a 10uf cap. (Due to splitting the cathodes doubling the cathode resistor is necessary to achieve the same bias point as before and halving the bypass cap (approximately) to give the same LF roll off.) For the bright channel then I will steal a page from Marshall and give 2.7k and .68uf a try for the cathode resistor. May have to do some experimenting to get it right. Also might try a .0022uf for the coupling cap on the bright channel.
So tonight I got the first bit of work done. I couldn't find a chassis that was the size I needed so I thought I'd try my hand at bending my own chassis for a change. I ordered some aluminum cut to size from a local supplier along with some 90 degree 2x1x1/8th angle for the end blocks and mounting to the cabinet. I don't have access to a sheet metal brake, so I ordered an excess of the angle to clamp to the bench to make my bend.
It took some experimenting to get it right, I ordered two 15"x11" aluminum sheets as I knew I'd probably fuck up the first one. It didn't turn out too terrible and with some work it will be usable for a later project but the second one turned out fairly nice. It still needs a bit of evening out with the hammer but I'm fairly pleased with how it came out. I then cut some 7" sections of the aluminum angle and I plan on brazing them to the chassis. I've never done this before but it doesn't seem too hard. If it doesn't work out I know someone who has a TIG welder that could take care of it for me. I also should add that .06" aluminum is a lot more ridged than I anticipated
Here's a few pics of what I got done tonight and a schematic and layout. Sorry for the smudges. I drew them a couple months ago and they've been lying around on my desk getting various beverages spilled on them.
http://imgur.com/a/jHc8f
I plan on building the amp into a mini head and cabinet configuration like I did with the single ended express. 1 12" speaker. Probably a Weber 1225 or the like. Though I'd like to make it a bit nicer this time. Round over corners etc. Probably will stain it something tweed-ish colored and make up a nice face plate for it.
Now where would a new amp be without a nice new guitar? My Dad has always wanted a strat, but I could never talk him into buying one. Well I've had this mighty mite body laying around for about a decade that I picked up at a guitar shop for a song. I'm planning on building that up as well. Probably a maple neck/fret board, white pick guard. SSH configuration with a mini PAF style pickup in the bridge. Here's a few pics of the body:
http://imgur.com/a/I3fZQ
