I am making a Mojotone JCM 800 2204 kit. This is my first amp, although i've done some pedals, and other electronic stuff before.
I have it completed and am trying to confirm everything is kosher before i put tubes in and crank it up.
From what i have read the bias voltage on pin 5 of V4 and V5 should be about negative 40-50vdc.
The problem is i'm getting -17.7 vdc
I am attaching a series of pictures that as far as I can tell show that I have 120 vac coming out of the wall, 360vac coming out of the PT, but only -23 vdc after the diode that i believe is supposed to rectify the dc bias voltage. and then it's -17.7vdc by the time it gets to pin 5. I should be seeing a much higher voltage after the diode, right?
Any help or ideas about what else to check would be really really appreciated. I'm a bit frustrated right now
