Heater artificial center tap
JoeCon
Post by JoeCon »
Guys
When a PT has no center tap for the heater circuit Merlin shows two 100 ohm resistors to ground as a hum reducing solution. Can these resistors come right of the socket pins of the first tube in the series or do you need a separate connection before the socket?
Thanx...
Deric
Re: Heater artificial center tap
Post by Deric »
Either way will work fine.
8)
Deric®
Post by Stevem »
They can be placed anywhere along the heater string.
JoeCon
Post by JoeCon »
Thanks guys, that's what I was hoping for...
