Structo wrote:I used my Brother label maker (awesome tool) and printed numbers which are then cut out and stuck on the tube.
We'll see how they hold up under heat.
Brother labels sure look neat but it runs into $$$ for the tapes.
For a long time now I've been using Avery labels intended for file folders, on tubes, tube storage boxes, inside amps etc. Before settling on the file labels, I noticed the stickum on labels would dry out, loosen up over time, and sometimes the boxes they're sold in were marked "temporary label." So.... what's PERMANENT? Only the file labels, the stickum seems to work over the course of years. And you can train your computer to print them either with blanks for you to fill in with pencil or super fine Sharpie, or with data printed if you want to go that far. I use 'em inside amps to record relevant data so the next time I go in, can compare power, bias current, bias voltage, hi voltage, what output tubes & what date I took the measurements.
To keep the stickum from excess heat I cut a strip of file sticker & apply it either over or under the glass next to tube plates on miniatures, or on the tube base for octals. If you need to remove the goop, a shot of solvent spray cleaner & Q-tip or paper towel gets it all off.
