Switch for Bridging Amp Channels?
guitarbyte109
Post by guitarbyte109 »
Hey guys.
I'm relatively new to amp building/modding and this is an idea that I've been playing around with that hopefully someone here will be able to shed some light on.
I was wondering if it would be possible to wire a switch that could act similarly to bridging the channels on a BF Bassman-style amp?
Thanks!
Brett
Re: Switch for Bridging Amp Channels?
Post by Stevem »
Yes, it's called a A/B box and tons of company's make them or you can find plans online to build one.
On the Bassman and many other amps just make note that you can not use bother channels at the same time as one is out of phase with the other due t o passing thru another gain stage!
JazzGuitarGimp
Post by JazzGuitarGimp »
More specifically, if you are looking to feed your guitar into both channels simultaneously, you will want an A/B/Y box, which allows you to feed your guitar into channel A by itself, channel B by itself, or "Y-cord" your guitar into both channels.
pops
Post by pops »
I have wired a mini switch into the jacks to allow either channel by itself or both at once. Not too hard, but you have to drill a hole. I usually put it behind the jacks up near the cab so that if it is center it is both, left and right for the channels that make sense, if that makes sense?????
The world is a better place just for your smile.
guitarbyte109
Thanks for the replies, I had considered going the A/B/Y route but was really interested in doing so without adding another pedal to the board.
pops wrote:I have wired a mini switch into the jacks to allow either channel by itself or both at once. Not too hard, but you have to drill a hole. I usually put it behind the jacks up near the cab so that if it is center it is both, left and right for the channels that make sense, if that makes sense?????
Yeah, that's exactly the sort of thing I had in mind. Would you by chance have schematic or picture of how you wired the switch?
pops
Post by pops »
I'll see if i can take a pic tomorrow, i think i still have an amp around with a switch in it. I can't post pic's tho as i have no hosting site and not interested in getting one so you'll have to give me your email address.
guitarbyte109
No problem, I'll send you a PM with the address.
Thanks again!
JMFahey
Post by JMFahey »
Stevem wrote:Yes, it's called a A/B box and tons of company's make them or you can find plans online to build one.
It's the "Reverb" amps which have 1 channel out of phase with the other, because the reverb mixing stage adds one extra inverting triode; the non reverb ones (including the "bass" ones), do not have that problem.
sluckey
Post by sluckey »
The 6G6 and AA165 both have 3 inverting stages in the bass preamp and only two inverting stages in the normal preamp, so they have the problem.
pops
Post by pops »
Sent you and email, hope it is what you need.
ValvElectric
Post by ValvElectric »
In case anyone else is curious, here's a quick layout I created with the information I've received.
Thanks for all your help!
Brett
